6 speed
blimmer86
Post Sun Jan 15, 2006 7:35 pm
im hope 2 do a enine conversion this year im thinl 2.7 but i want a six speed box iz this possible or am i livin in a dream world
cheers
matt
toby
Post Sun Jan 15, 2006 7:59 pm
I've read somewhere about 6 speed conversions and it wasn't recommended.
I think it would require a longer gearbox and changing transmission parts. Better to upgrade your differential to get better acceleration, maybe.
Ah found it -
"Could it be done? Sure, but why would you want to? Six-cog gearboxes have a great deal more to do with marketing and one-upsmanship than they do actual performance benefits. Most cars with sixth-gear intergallactic overdrive, including the E46 M3 in my opinion, do not have sufficient differential gearing to take advantage of the fact."
Quoted under BMW Project
http://www.europeancarweb.com/tech/tech ... index.html
toby
Post Sun Jan 15, 2006 8:01 pm
I forgot to mention this is an American site and the BMWs over there tend to be a bit different but may still be the same with regard to changing gerbox anyhow.
blimmer86
Post Sun Jan 15, 2006 8:04 pm
i just wanted some one 2 chase me and see that im goin flat out in 5th and then all of a sudden 6th :D cheers anyway
toby
Post Sun Jan 15, 2006 8:07 pm
I know what you mean - I had thought the same thing - that's how i found that article.
I would be interested to see if the more technically minded folk here have any opinions...
ian332isport
Post Sun Jan 15, 2006 8:29 pm
Fitting a 6 speed box is not going to make any difference to how fast the car goes.
6th gear is the same ratio as 5th in the regular 5 speed E30 box. The extra gear is in the lower gears and is designed to allow you to have closer ratio's.
You can physically fit an E36 M3 6 speed box on an M20 engine, but it's more trouble than it's worth.
Ian.
