323 1986
- theretroking
is the fuel pump relay and thermostat housing the same as the 325 thanks in advance.
- theretroking
the relay that i need is the long black one with 5 connectors, sits alone on the inlet side under a black cover that pulls off. will this bee the same as 320 325 ?.
Thank you.
Thank you.
- **BANNED**
No,later E30 use the 4 pin relay mentioned by the sheep lover above...theretroking wrote:the relay that i need is the long black one with 5 connectors, sits alone on the inlet side under a black cover that pulls off. will this bee the same as 320 325 ?.
Thank you.
Good news is that E28 also used the black 5 pin FPR.
Youth is wasted on the young.
- theretroking
Thanks all for your help
