Turbo advice (gunni)
themaverick999
Post Sat Jul 11, 2015 1:16 pm
Hi all been doing some reading and im wanting more power from the m20b25 looking for 300bhp seems achievable without a headache
I am expecting to get shot down here as its been mentioned loads
The things I understand I need and can buy easy are as follows:
ebay mani
Decent turbo (not chinese)
Intercooler
uprated clutch
Im presuming the following:
Chip for standard ecu
Local exhaust place will fab a turbo back exhaust
30lb injectors will do the job
Now I have asked for Gunnis advice as it seems he is the guru on this matter please dont be offended if you have loads of info too
Essentially my understanding is a s follows,
bolt mani on
bolt turbo on
oil feeds ???
wastegate???
plumb in the intercooler
bov??
fit the chip
fit the injectors
how wrong am I? Does Gunni do a kit ?
thanks
JF008
Post Sat Jul 11, 2015 3:15 pm
Schmiedmann does an m20 turbo manifold for £400.01 according to there advert on the back of the first page of the Performance BMW magazine :)
themaverick999
Post Sat Jul 11, 2015 11:53 pm
thanks for the help so far guys
ross_jsy
Post Sun Jul 12, 2015 12:24 am
This is a good read for turboing m20's:
http://www.e30tech.com/forum/showthread.php?t=74816
Don't try and fanny around with chipping the standard ecu and using a rising rate FPR and all that nonsense. If you are going to do it, and have a car that drives nicely, standalone is the only real option. Megasquirt and VEMS both do plug and play options if you aren't up to wiring. Another option would be:
https://www.millerperformancecars.com/s ... m20-detail
However, personally I would pick a proper MAP based standalone over that
DirtyP
Post Sun Jan 01, 2017 7:13 pm
Digging this up from the past, as e30tech doesn't seem to exist anymore and a was a good source of info in some cases did anyone ever create a guidance thread in here for m20 turbo installs?
Or can anyone recommend some good build threads?
jimmyspeed
Post Sun Jan 01, 2017 10:41 pm
There a couple of good build in this lot and some parts lists etc- the e30 tech list was useful I'm sure it will be about online somewhere. Try searching this forum too, as lots of people have successfully built turbo m20/m30 etc - use the search all terms to get a more specific result
http://www.maxbimmer.com/forums/showthread.php?t=123578
http://www.r3vlimited.com/board/showthr ... 271&page=3
http://www.bimmerforums.com/forum/showt ... urbo-Motor
http://www.bimmerforums.com/forum/showt ... Megasquirt
steve_k
Post Mon Jan 02, 2017 9:57 am
iirc lurch_320I was selling a complete m20 turbo set up a while back.
Pretty cheap as well.
ross_jsy
Post Mon Jan 02, 2017 10:44 am
If you are not already, come join Boosted e30 World on facebook
DirtyP
Post Mon Jan 02, 2017 11:53 am
Thanks for the feedback gents, I don't really use facebook. I read Lurch project build, seemed to have almost got it all done and then decided to sell up?
A lot of the info across the forums seems to date back a few years with references to eBay manifolds etc, I'd assume it'd be cheaper now. There is a sticky on this page but most of the links are dead links now which is a shame.
ross_jsy
Post Mon Jan 02, 2017 8:09 pm
It's definitely not cheaper, but parts are a lot easier to find. eBay manifolds are still junk
Gt40e30
Post Sun Jan 27, 2019 11:27 am
30lb injectors will be running at around 90% duty for 300hp I would go a bit bigger .
