Hi All,
Getting a nasty whiff of petrol on start up, having done some wiki'ing sounds like I might have a seal gone on an injector (or least its a point to check off), so I'll give them a clean while I'm at it (which I'm sure they will need/benefit from), so will need to fit new seals when I am refitting them.
I've got a 91 320, can anyone recommend a supplier? I've looked on e-bay but most of the suppliers are in the US, and I was hoping to get it sorted this weekend if possible.
If anyone can point me towards a seller I'd be very grateful.
Injectors O rings seals
BackinBlack
JF008
injectoretune can sell you individual parts or could clean and rebuid your injector for £60. You can get the o rings from BMW as well. They might be perished or a fuel hose or loose clip...
BackinBlack
£60 for that service looks like a no brainer!! Thank you for coming back to me. I'll take a proper look-see at the weekend and see if there are any leaking fuel hoses or loose clips...
The injectors would probably benefit from a damn good clean anyway
