Hi,
I have a prefacelift convertible and the windows are live without the key in the ignition, I am guessing I'm right in thinking that this isn't normal and if so does this mean someone has wired them into a permanent live?
I can't remember if my last convertible did this, but I don't think it did.
Thanks in advance
convertible electric windows live without ignition on?
matt86
BenHar
Should only be live with ignition off if a door is open.
Check that one of the plastic knobs that actuate the door switches isn't missing.
Ben
Ben
This is true with factory fitted electric windows. Dealer fitted windows don't use the same parts as factory fitted, and may be wired differently.BenHar wrote:Should only be live with ignition off if a door is open.
matt86
Brian and Ben thank you for your advice, I will check this and get back to you, as I can't remember if when I was pressing the switches it was with the door open or closed now
Thank you
Thank you
BenHar
Did any convertibles leave the factory without electric windows?Brianmoooore wrote:This is true with factory fitted electric windows. Dealer fitted windows don't use the same parts as factory fitted, and may be wired differently.BenHar wrote:Should only be live with ignition off if a door is open.
Ben
You might have a point there! I really should read posts more accurately.BenHar wrote:Did any convertibles leave the factory without electric windows?Brianmoooore wrote:This is true with factory fitted electric windows. Dealer fitted windows don't use the same parts as factory fitted, and may be wired differently.BenHar wrote:Should only be live with ignition off if a door is open.
Ben
