318i Tapping when over 2k
chipbitz
Post Mon Jun 22, 2015 5:34 pm
Hello!
I've got a 318i M40B18 and when it's over 2k revs (Pretty much on the dot) I hear a tapping, and then when it goes under 2k it goes silent which makes me doubt tappets?
It's only recentlly had
New valves, Cam, Rockers, +0.5 oversized pistons and a load of other work to it, so i'm a bit confused
anyone got any clues?
Post Mon Jun 22, 2015 6:00 pm
What was replaced on the head?
Maybe a lazy/worn lifter
chipbitz
Post Mon Jun 22, 2015 6:06 pm
This is what i had done, Engine runs lovely besides the tapping
Valves
Cam
Rockers
Head skimmed
New guides
crank and rods balanced
ACL bearings
Rod Bolts
and a new belt kit
blazed
Post Mon Jun 22, 2015 6:08 pm
did you replace the oil spray bar?
chipbitz
Post Mon Jun 22, 2015 6:10 pm
I didn't no, not getting enough oil?
blazed
Post Mon Jun 22, 2015 6:15 pm
they are the weak point as they get blocked.
you can drill out the holes to make them bigger or just change for a new one
http://www.gsfcarparts.com/parts/engine ... ation-pipe
chipbitz
Post Mon Jun 22, 2015 6:23 pm
Ahh I see, thanks for the info and the link! :)
