Control Arm Replacement
Racer75
Tue Jun 09, 2015 3:21 pm
Anyone got a good guide on front control arm replacement?
Can't seem to find a good source.
Grrrmachine
E30 Zone Wiki / Team Member
Tue Jun 09, 2015 3:35 pm
1) Jack up the car on stands and take the wheel off.
2) Undo the nut on the outer ball joint. Jack up directly beneath to place pressure on the joint to prevent it spinning.
3) Do the same for the inner nut.
4) Using a ball joint splitter, separate the outer ball joint from the steering hub. If you don't have one, try refitting the nut to the top of the ball joint, then clout it with a hammer.
5) Repeat for the inner joint.
6) Undo the two bolts holding the lollipop bush to the subframe. The entire control arm will now fall off the car and onto your foot.
7) Fit the new control arm
8 ) Put the wheel back on.
I never did a wiki writeup for it because it's really that simple - 2 nuts and 2 bolts per side.
Racer75
Tue Jun 09, 2015 3:50 pm
Cool
Thats exactly what I needed
Thanks again
