m60b40 steering pump noise
gooseygander110
Mon Jun 08, 2015 1:00 pm
I seem to have an odd problem......have fitted the rebuilt E46 (i think !) purple tag 2.7 turn rack and used the E34 pump....... first one was knackered so tried a spare......... only to have a dry bearing type noise from pump....... tried a new one ......very similar noise :mad: am waiting on a a 3rd known good one ....... Am I just unlucky with pumps or does anyone have experience of this ?
Mikey_Boy
Tue Jun 09, 2015 8:47 pm
Does it happen both with the steering fluid cold and hot??
gooseygander110
Tue Jun 09, 2015 11:15 pm
I haven't driven it yet .....still on the ramp :mad: so cold deffo......... I have had the car at normal temp but the PAS fluid would still be maybe warm at most .......
Mikey_Boy
Wed Jun 10, 2015 6:36 am
I had something similar with my Z3 rack when I fitted a cooler to it with both my M20 and S14. Awful noise when cold, but disappeared when hot. When I removed the cooler loop, everything went quiet. So I'm not sure if there is some sensitivity of the pump to pipe lengths in the circuit or whether I just have PAS pumps on the way out. I'd like to think I've discovered something new, but just have a feeling we might all just be running pumps that are dying!!
Might be worth looking at how your pipes are routed and get that as close to standard as possible? Otherwise, looks like pump number 3! They are incredibly intolerant of dirt and dust so might be worthwhile tackling a DIY rebuild??
Wed Jun 10, 2015 9:01 am
If its an E34 pump it may be one with a second output for rear self levelling suspension, 3 ports in total. One thing to note is the working pressures of pumps for steering boxes is usually higher than pumps for racks
gooseygander110
Fri Jun 12, 2015 1:48 pm
Thanks guys for your input ...... I had a chat with the chap who sold it to me and reckons it is a 2.7 turn Z3 1.9 rack which was very light anyway ....so the next step is to get a Z3 pump and make that fit 8O :mad:
Wish me luck and watch this space :roll:
Fri Jun 12, 2015 6:59 pm
Any E36 or E46 M52 pump will be fine
gooseygander110
Sat Jun 13, 2015 1:52 pm
Thanks guys..... WillNZ did you also have the 2.7 Z3 1.9 rack ? I have got a 1.9 Z3 pump arriving on Monday .......worried it might be to light now :mad:
gooseygander110
Sun Jun 21, 2015 9:39 am
Hi guys, just to let you know .......a modified E46 M52 pump has done the trick............. steering with 2.7 lock to lock is a dream :D well worth the mucking about 8) #
gooseygander110
Tue Jul 07, 2015 8:08 pm
Ok ....will do ...... sorry been so busy ....will get one up very soon 8)
