E30 has been stood for ages. 318iS stock brakes.
Looking to strip and overhaul the brakes. Anyone know of a full rebuild kit available? Or if you've done the job and kept part numbers for seals, clips, bleed nipples pistons etc?[/list]
Caliper Rebuild Kit?
jimmyspeed
I used the bigg red kits and they are well made, they also do new pistons. Bmw also have rebuild kits at around double the price.
If your going to need new pistons, seal kits and re plating the new callipers on carparts4less aren't bad value. I can't comment on there performance but think they're pagid from memory so can't be too bad.
Check whether you have the grilling or ATE brakes before you order
These stainless bleed nipples are good and cheap - http://www.ebay.co.uk/itm/HEL-Performan ... 4adc711c84
heres the link to big red on ebay.
http://stores.ebay.co.uk/biggredltd_W0Q ... 1&_nkw=e30
- BHadley
- Contact:
Yep, these are good. I bought some too ....
