My clutch pedal has always been heavy and I'm going to replace the clutch.
I've seen on ECP and CP4L a Sachs kit for the 325i part number 641110100, can somebody confirm this is the correct kit for the 325i as I recall reading on this forums about problems with different size friction plates.
This one is worryingly states 228mm and 230mm in the same description.
Sachs Clutch Kit
they sent me an LUK clutch so i exchanged for the one i ordered a SACHS one and guess what ...... another f00kin LUK one turned up !
i got a refund and found a motor factor called Andrew page who got me the correct clutch for £115 after i asked for discount , here is the branch locator below .....
http://www.google.com/url?sa=t&rct=j&q= ... 0622,d.ZGU
if you live in jockland your f00ked
+ a yard full of scrap turds
PG325
Tried Andrew Page, apparently SACHs is not available, offered LUK at £140, might have to tempt luck with CP4L, their kit is £102 after discount, apparently SACHS but unlikely.
Are LUK any good?
Are LUK any good?
Luk are OEM. There just as good as Sachs.
If you're looking for a lighter clutch, go for one for a 2.0 litre M20 E30. Assuming your 2.5 engine is near enough standard, and you don't make a habit of abusing the clutch, it will be up to the job.
The difference is the cover plate, which is fitted with a less strong spring.
PG325
Well I've ordered the CP4l Sachs kit at £102 which included their £15.00 off if you spend over £100.
Spoke to a nice lady via internet chat who confirmed it is Sachs as the LUK versions have a slightly different part number ending with an L, whatever turns up for £102 delivered I can't grumble.
zd3bx
Be careful with Sachs kits, because I remember trying to order one from ECP few years ago and they kept sending me the wrong one...
The correct Sachs part number for a 325i is this > 3000 132 002
You can download the Sachs catalogue from here and check yourself > http://www.zf.com/brands/content/en/sac ... alogs.html
In the end, I ended up buying mine from GSF. They only had LUK, but at least it was 100% correct for my car.
Jesus325iTouring
- Frog freak !
Hope you got the right discount Mick, they have the special "Mickey Mouse Discount" for a lot of people!magpie wrote:they sent me an LUK clutch so i exchanged for the one i ordered a SACHS one and guess what ...... another f00kin LUK one turned up !
I get one up from that, trade, but not motor trade, still saves me around 30-40% on anywhere else though.
Top infozd3bx wrote:Be careful with Sachs kits, because I remember trying to order one from ECP few years ago and they kept sending me the wrong one...
I think you posted several years ago that ECP supplied you an E28 M20 clutch that is actually for a lower powered engine, 525e part number 3000 132 003, which will be a lesser clutch than the proper E30 325i unit
As Brian says it would probably be fine for a standard 2.5 engine, but a lot of people that are looking for Sachs clutches are fitting them to uprated or different engines
i'd have no problem with LUK and a standard ish b25
i've heard some bad reports with LUK + 24v , never heard anything bad about sachs .
