Passivating kit
ross_jsy
Post Fri May 15, 2015 12:48 am
After seeing Jim's thread, decided I need to get a load of parts passivated as things are looking ropey, however after making inquiries, there's no one who does it locally.
Wondering if anyone has had any success with the kits you can buy online?
Ross
HairyScreech
Post Fri May 15, 2015 9:49 am
Got a link to the kits?
Passivating is something I probably can give decent advice on. :mad:
ross_jsy
Post Fri May 15, 2015 10:11 am
This is the one I had seen, but there's quite a few available:
http://gaterosplating.co.uk/Zinc-Nickel-Plating-Kit.php
BMG
Post Fri May 15, 2015 10:18 am
Nut used one, but this thread does show that these kits can produce excellent results.
http://www.detailingworld.co.uk/forum/s ... p?t=182810
Post Fri May 15, 2015 3:33 pm
ross_jsy wrote:After seeing Jim's thread, decided I need to get a load of parts passivated as things are looking ropey,
What exactly do you mean by passivating ?
Post Fri May 15, 2015 5:13 pm
Trevor B7 had a go with a home kit with mixed results.
I've been using collinschemicalblacking.co.uk for several years now.
Post Fri May 15, 2015 5:17 pm
Its an electro plate process that was used on various fittings and parts on earlier BMW's including E30's.
Many parts when bought new from BMW are not done in this finish anymore due to EU legislation.
Jim's been getting a bit carried away with it recently. Plating things that were never plated such as the tool kits in the boot tray! :mad:
Post Fri May 15, 2015 6:26 pm
bss325i wrote:Trevor B7 had a go with a home kit with mixed results.
My kit works but to be honest? it's all a bit heath robinson and long winded to be honest.
Mitchen
Post Fri May 15, 2015 7:15 pm
Haha! Jim loves the bling!
1990 320i Coupe SE
viewtopic.php?t=253048
jimbom30cab
Tech 1 freak
Post Fri May 15, 2015 8:12 pm
Yer, the bling is cool and a bit of fun !! The place I use are ace, bascially they charge £40 a batch and don't mind at all how much is in the batch.
bab-91
Post Fri May 15, 2015 8:15 pm
Jozi had success with this iirc.
IG - bab91
