M20 323i Cranks and Sparks but no fuel
H23
Post Sat May 02, 2015 1:01 pm
Hi team,
As the titles says. 1984 323i H23 (L-Jet)
Replaced fuel pump, filter and relay but still not getting fuel to flow.
How do you test to see if power is getting to the pump?
Anything else I should look at?
George
H23
Post Sun May 03, 2015 5:22 am
Thanks heaps,
Fuse 11 ok (put new one in anyway)
Bridged those pins and tester lit up but no pump sound.
Put tester on pump and no light .... at least I know its at the pump !
Unhooked wires at pump .....No light on wire feeding pump..
Thanks again, I'm getting close now.....
Andyboy
Alpina Colada
Post Sun May 03, 2015 8:35 am
Sounds like a 12v interruption between the fuse and the pump - dodgy alarm wiring? Run a wire from battery + direct to the pump and ensure the earth is good. If the pump runs, refit the relay OR make up a three legged link for 30, 87 (injectors) and 87b.
H23
Post Mon May 04, 2015 11:19 am
Huge thanks to WillNZ & Andyboy,
With your help I was able to eliminate posible area's ?
It ended up being dodgy alarm wiring .....
Thanks gents.
**BANNED**
Post Mon May 04, 2015 11:26 am
Remove the glove box liner and search out the plain green wire.
This should run from the ign switch to the switch side of the coil,passing through the engine loom plug and a plug/socket behind the glovebox,this latter connection is used to break the wire for an alarm.....
Youth is wasted on the young.
H23
Post Mon May 04, 2015 2:42 pm
She's Alive !
It was a dodgy solder on th a that wire after all.... but the break was behind the dash/under the steering wheel.
Thanks gents - much appreciated.
Now I can get it to the wheel aligner after fitting my Z3 rack !
