Can anyone help me with a radiator problem?
Need to know if the rad from a 320i will be the same size as the 325i one?
Any help gratefully received
Chris
Help wanted on size issue!!
chrisuxi
kam-325i
They are the same size, but you can get early and late versions...
chrisuxi
Thank you for your help.
Do you know if a 525 engine is the same as a 325? i.e. will it drop straight in?
Regards
Chris
Regards
Chris
Zayyan
If you're talking about the E34 5 series, an engine from an early 525i will be the same, though they changed the engines around 1991.
