injectors
gnrsoul
Post Tue Apr 07, 2015 1:54 am
Would m50 injectors fit m20?
motormanmick
Post Tue Apr 07, 2015 7:59 am
Yes, you would need to check that the impedance is the same, you are obviously looking at an up grade, so probably the best way to go would be disc type 4 hole for a better spray pattern and go for roughly the same delivery rate.
I used this website to match my m50 2.8, by looking up 1st what is used in m52 2.8 and then cross referencing with disc type 4 hole, same ecu connection, type EV1 and high impedance and slightly better delivery rate and found a ford injector, which looks a bit different but fits like a glove. Just look up the bosch section and start checking the specs, cheers.
http://users.erols.com/srweiss/tableifc.htm
