front fog light
torquey
Mon Apr 06, 2015 11:28 pm
As above,my nearside foglight is coming on when my lights are turned on but its turned off at the dash switch any ideas would be helpful, thank you.
Mon Apr 06, 2015 11:38 pm
Check the earthing point on the LH inner wing, near the front.
Anyone been swapping relays in the fusebox?
torquey
Mon Apr 06, 2015 11:58 pm
Hi Brian,thanks for your reply, i had the wing replaced sometime ago so its possible thats where the fault may be,as regards the relay i have no idea if it's been touched if so what relay should it be? Thanks.
Tue Apr 07, 2015 12:11 am
Should be two identical black five pin relays at one end of the fusebox. The rest either should be orange four pin or empty sockets (apart from the large wiper control module.)
