Are there any engine setting tools for the m20?
If so, where can I buy them other than the stealer?
m20 locking tools
gcorky
- Boost Junkie
no m8 these are marked on pulleys/plates
belt/tensioner and waterpump would be fitted ideally as any 1 failing would result in the same!!!!also tensioner on this engine(spring loaded) is self tensioning initialy then rotate engine few times as normal then tighten tensioner.
