Difference in crank and Conrod bearings
Driftben
Post Sun Mar 29, 2015 3:44 pm
Oi Oi
I'm currently replacing the main bearings and conrod bearings on my M60 and wondered what the colours of the shells ment when the tolerances were the same?
Like seen here
http://realoem.com/bmw/showparts.do?mod ... g=11&fg=20
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
Post Sun Mar 29, 2015 7:19 pm
The green white and yellow are all different sized further to the standard and oversized
So you have standard sized, in 3 different sizes
+0.25mm oversized in 3 different sizes
+0.5mm in 3 different sizes
etc etc
I cant remember the actual size stages but a google search should find them
The blue and red big ends are simply just top and bottom
Driftben
Post Sun Mar 29, 2015 7:53 pm
from what iv found so far after hours of searching,
the crank should be marked with a colour dot which denotes the colour of shell/bearing which needs to be used. I need to confirm this though.
these are what my bearings look like, what do you recon?
6pot wilwoods front
4pot Porsche rear
Post Sun Mar 29, 2015 10:55 pm
Defo change the big ends, you can see the coating is wearing through on that first one
Driftben
Post Sun Mar 29, 2015 11:21 pm
Yea that's what I thought.... Bugger that's more money and time until I can build it back up :roll:
Another call to bmw by the sounds of it
6pot wilwoods front
4pot Porsche rear
Driftben
Post Mon Mar 30, 2015 10:15 pm
well it came in at £611 for main bearings, big end bearings and a set of new crank cap bolts 8O
might need to look for alternate options :(
6pot wilwoods front
4pot Porsche rear
Post Mon Mar 30, 2015 10:29 pm
The big ends are not normally massively expensive, and thats your priority
Driftben
Post Mon Mar 30, 2015 10:41 pm
Yea the main doesn't look too bad but if you look in the picture you can see slight wear so I'd thought id replace the lot not knowing the cost a˜“
I have some plastigauge coming tomorrow so I can check the tolerances. Should be too far out as Iv caught this pretty early
6pot wilwoods front
4pot Porsche rear
