Hi, will an E36 crownwheel and pinion fit my E30 casing? I've got a medium case LSD 3.91 and I want to put a longer ratio in it. Like a 2.93 or 3.15 and have seen a few E36 diffs on ebay.
Tom
E36 diff ratio in E30 casing?
TomCresswell
age
- Formerly twist316
yes it will.
M40 rightness if you can get to 6000rpm noone can hear your tappets
heathy325
Yes it will I've just done this myself
craigieeb
Is it an easy process?
I thought you needed to space them correctly etc
whats actually involved..?
is it just as simple as taking out/off the old and torquing up the new ratio?
M50 Turbo!!!
I shall say no more
Its not just nuts and bolts as you have to ensure the mesh and preload are correct.
Not all 188 CW/P are compatible with all 188 diff spools, as I explained to you on the phone the other day Tom and im 99% certain you will not be able to fit that 2.93 CW/P to your 3.91 LSD unit
TomCresswell
Aha, forgot about that. Cheers.
If all is well at work tomorrow I'll see you tomorrow late morning Dan.
TomCresswell
You want about 6-8 thou backlash (rotational rattle) on the pinion gear when the things torqued up.craigieeb wrote:Is it an easy process?
HairyScreech
Your far better off with a Z3 6 cylinder diff and just fitting the LSD unit.
It will already come in the correct housing.
gareth
CorrectDanThe wrote:Its not just nuts and bolts as you have to ensure the mesh and preload are correct.
They do need to be set up properly though, i reckon 1/3 of the rebuilds that find their way to me are entirely due to someone "having a go at it"
