Is the only difference with a convertible wing the sill part?
If so, would it then be possible to get a standard wing and add the convertible sill part or fabricate the convertible sill part?
Thanks in advance....
Front Wings...
Yes and yes. The lowest part needs to be cut off of a saloon wing, and the longer cab. part welded on. The join is under a trim piece, so doesn't have to be too pretty.
This has been on here several times.
BenHar
And the bottom part is easily fabricated so you don't have to find a cabriolet wing that isn't rotten there.
Ben
Ben
Gavla
Thank you gents...needed to double check!
