couple of build questions
midge11
Fri Mar 13, 2015 5:14 pm
Right got the lump in its new home so now im connecting everything up and ive got a few bits I cant figure out .
1st on the breather pipe out of the rocker cover mines been bodged and a vacuum hose connected to it that then goes to the bottom of the inlet . Is this right and someones bodged the pipe ?
2nd on my brake servo pipe it have a white valve thing that also has a vacuum connector but cant find any loose vac hoses to connect to it
Any help much appreciated
Mick
Bristol_Jer
Fri Mar 13, 2015 8:55 pm
Does your rocker cover pipe look like this one? That's how it should be:
I can't remember 100%, but I don't think you need any of the smaller pipes on the vacuum valve, just the main large one for the servo
midge11
Fri Mar 13, 2015 10:57 pm
Ye that looks like mine but mines been bodged and taped up . And cool ill just blank off the other pipe on servo then
Thanks alot matey
Bristol_Jer
Fri Mar 13, 2015 11:13 pm
The new hoses/pipes were pretty cheap from BMW when I built mine up, might be worth a call to your local dealer or Cotswold on here
All the best with your conversion :thumb:
midge11
Fri Mar 13, 2015 11:30 pm
Another quick question . Charcoal canister my e30 didnt have one but there 535 I stripped did so did you put it on or just get rid ?
Bristol_Jer
Sat Mar 14, 2015 2:32 pm
Just got rid of it, you don't need it :)
Sat Mar 14, 2015 3:08 pm
midge11 wrote:Another quick question . Charcoal canister my e30 didnt have one but there 535 I stripped did so did you put it on or just get rid ?
You don't need it, as above, BUT you must leave the pipe to the back of the car open, and must blank off the one to the inlet manifold. The solenoid valve isn't required either, but removing it will cause a fault code to be logged by the ECU. If you don't want this, either just tuck the valve away somewhere, leaving it connected electrically, or a resistor can be connected in place of it.
midge11
Sun Mar 15, 2015 8:22 pm
a˜Š Thanks Alot
midge11
Fri Mar 20, 2015 2:58 pm
right chaps struggling with wiring on this , firstly mines the early square block connector so not a straight forward swop ive got the diagrams but cant figure out where all the diff wires should go , has anyone got a actual pic of this wiring swop ???
second my coil wiring on the e34 loom it has 4 wires the go towards the coil now ive tried every combination possible and still no spark the weird thing is one of the terminals is smaller which logic seems that that is the earth as the earth terminal is smaller but I have no feeds to it and if I connect a live feed to the coil and this wire it just goes to a live and obviously no spark :(
any ideas anyone or has anyone got pics of the coil wiring
cheers again mick
Bristol_Jer
Fri Mar 20, 2015 6:00 pm
Can you get a pic up of your coil wiring? From memory there is 2 wires going to the coil, one with the eyelet bigger than the other, and a couple of earth wires on the same bunch of wires.
Can't help with the early square block connector sorry, is that instead of the round c101 connector?
midge11
Fri Mar 20, 2015 7:28 pm
Ye that sounds right . The one with the smaller eyelet is ment to be the earth but there is no feeds dpwn it what so ever . Where does it get its earth from this wire
Fri Mar 20, 2015 7:33 pm
If you want wires identified, then you have to accurately state their colours.
midge11
Fri Mar 20, 2015 8:24 pm
Ok so from my Square plug its pin 6 thats green and pin 1 which is blue where do they go on.the e34 c101 plug
Fri Mar 20, 2015 10:21 pm
Plain green is switched ignition live, and plain blue is the battery warning light. Not sure what you mean by "E34 C101" since the C101 is only found on an E30, but the colours should be the same on both looms.
midge11
Fri Mar 20, 2015 10:25 pm
Sorry I ment e34 x20 loom
Fri Mar 20, 2015 10:33 pm
Brianmoooore wrote: but the colours should be the same on both looms.
Still applies.
midge11
Fri Mar 20, 2015 10:45 pm
There not thats the problem
Bristol_Jer
Fri Mar 20, 2015 10:58 pm
Get some pics up of the wires and loom Mick! :)
midge11
Fri Mar 20, 2015 11:40 pm
Cant upload off my phone can I email u them see what u think
Bristol_Jer
Sat Mar 21, 2015 8:08 pm
I'll PM you my email address and put the pics on this thread for you
Bristol_Jer
Mon Mar 23, 2015 7:37 pm
midge11
Mon Mar 23, 2015 8:15 pm
Thanks alot mate . So ive got the square block and I need to match them up to the x20 loom . Anyone ??
Cheers mick
aryahmmr
Wed Dec 09, 2020 10:06 pm
This matches my square C101 for my 1985 325e. How can I get the wire gauges? Rats chewed through one end and I need to redo the molex connectors.
Wed Dec 09, 2020 10:30 pm
You mean the size of the wires?
Only the green, black/yellow and green/purple carry any significant current, so 1.5mm2 min. for them and smaller stuff of choice for the others.
Don't forget that you have a second engine loom plug (C104?) behind the instrument cluster/above the ECU for the engine and road speed signals.
