14mm fuel breather hose relocation
andrew_baran
Post Fri Mar 13, 2015 11:37 am
I've got GAZ coilovers on my Touring, and the rear right spring rubs on the metal cover in the photo below:
The two small lines are OK - I can "massage" the cover to give enough room without crushing them. But the 14mm breather hose won't fit.
I was thinking of two options:
- Running the 14mm hose in a new routing, tightly tied against the fuel filler neck for example.
- Reducing the 14mm hose to 8mm, running it through the channel as standard.
Opinions?
