Hi,
My 323i's automatic transmission coolant line has sprung a leak around the radiator end. the car has no AC. So needs the more pricey varieties.
The OEM part shows in the etk as a nut joint, whereas what is on the car is a banjo fitting to the radiator and the nut type fittings on the gearbox housing.
17221177984, 17221707538
Does anyone have any experience with these parts? I hope to order from Germany, thanks to the weakening euro.
http://www.realoem.com/bmw/showparts.do ... g=17&fg=05
Thanks for any suggestions and any vendors that might stock it.
