2.7 Stroker Build questions
DaleJK
Post Tue Mar 10, 2015 12:56 am
Okay so i've decided to build a 2.7 Stroker instead with my M20b27 bottom end and 325i top end my buddy has (May eventually turbo it 8) ), Just again wondering if theres anything i need to pay attention to or may need to adapt for it to be put together, just looking for general things ill need to know as im sure its not as simple as lego :chuckle:
Many Thanks
Dale
Lurch320i
Post Tue Mar 10, 2015 7:37 am
Not 100% but I think you need the 325i Pistons to go with the 885 head
You can put a standard 2.0 731 head on the 2.7 block but doing all that work why bother with anything sub optimal
reggid
Post Thu Mar 12, 2015 7:53 am
dont do a 2.7 unless you are certainly going to turbo, if you will likely just stay NA get an m52b28 crank and b25 pistons if you can? it will be miles better than low comp 2.7
E30 325is with M20B31
DaleJK
Post Tue Mar 17, 2015 8:02 pm
Okay thanks Lurch and reggid i do plan on going turbo with the setup before it gets put into the car
