Piston - Valve Clearance
From what I can see in the picture I wouldnt be happy with that, what have you changed?
knapmann
I have a 285 Catcams Cam, and stock pistons and valves etc.DanThe wrote:From what I can see in the picture I wouldnt be happy with that, what have you changed?
reggid
have you dialled in the cam properly with adjustable pulley? you could get a die grinder to give some more radial relief by laying back the pockets, just make sure the shavings don't go anywhere you don't want them to
E30 325is with M20B31
It might just be the picture but id expect to be seeing 1mm clearance at least there
Like this -
Like this -
