Non genuine fuel pumps Update - Fitted
Post Thu Feb 26, 2015 1:40 pm
I need a new one and there is loads on the 'bay for about £30 brand new with guarantee for unknown makes, but if you want a genuine Bosch jobbie it's £100 upwards
Has anyone used one of the ebay ones and got feedback good or bad ?
The going rate for a good used one seems about £40 but that seems false economy when there is no guarantee of how long it will last
Post Thu Feb 26, 2015 1:58 pm
Ive fitted the non branded stuff before and had to replace it weeks later, last in tank pump I fitted was a Meat & Doria (high quality) from ECP, was about £90, they couldnt get Bosch and I couldnt find any online to match the part No either
Post Thu Feb 26, 2015 6:38 pm
Ok mate I might take a punt on a used genuine one then
zd3bx
Post Thu Feb 26, 2015 7:26 pm
It's worth buying a new genuine Bosch one, even when it's £100+, especially if you plan on keeping the car. You will know you won't have to worry about that for the next 10 years.
Do it once, do it right.
aze30
Post Thu Feb 26, 2015 9:59 pm
DanThe wrote:Ive fitted the non branded stuff before and had to replace it weeks later, last in tank pump I fitted was a Meat & Doria (high quality) from ECP, was about £90, they couldnt get Bosch and I couldnt find any online to match the part No either
i think these are pierburg items in meat and doria packaging....pierburg are an OE quality brand so win win :)
Kedge
Post Fri Feb 27, 2015 8:49 am
You may as well buy the cheap unbranded new ones instead of a secondhand one Rob, my experience of old pumps has taught me they're a waste of time as well.
Instagram - Kedge85
HairyScreech
Post Fri Feb 27, 2015 1:24 pm
Forget a second hand pump.
The cheap gear types are reliable but are A, noisy and B, too high a flow delivery so put more strain on the regulator.
As above any of the good quality aftermarket ones from Bosch, peirburg, etc should be reliable.
Post Fri Feb 27, 2015 10:37 pm
http://www.ebay.co.uk/itm/Bosch-Fuel-Pu ... 4617034ac7
Looks like this will have to do then
Post Sat Feb 28, 2015 12:31 am
Its the wrong pump Rob, ive had it from GSF before, and another 3 different part numbered pumps following. They were all wrong. I even gave them the part number from the correct pump supplied by ECP and they couldnt match it :roll:
Post Sat Feb 28, 2015 6:28 am
Aargh ! I'll get it out and get the part number off it and go from there I think.
Post Sat Feb 28, 2015 10:27 am
But they las 25 years? I've kept the fuel pumps off every breaker for this time. I've got about 5-6
I bet the new OE ones from BMW won't last like the originals did. But they don't sound break the bank expensive really
Post Sat Feb 28, 2015 12:54 pm
Have you got a known good one that will fit my car Si ? :D
zd3bx
Post Sat Feb 28, 2015 1:40 pm
capri_rob wrote:Have you got a known good one that will fit my car Si ? :D
Try BM Mini Parts, put your last 7 digits of the VIN there, find the pump and get a quote for one.
You'll be surprised how cheap some of the genuine stuff is. Well, "cheap", relatively speaking...It won't be 50 quid, but it's worth finding out.
JF008
Post Sat Feb 28, 2015 6:56 pm
Was the Meat and Doria noisy Dan? I will replace my fuel pump this week and will get that one if the price I get from the dealer on monday is too dear. I don't want to hear it tho :)
Kedge
Post Sat Feb 28, 2015 7:20 pm
Simon13 wrote:But they las 25 years? I've kept the fuel pumps off every breaker for this time. I've got about 5-6
I thought a known good working pump would be fine sat on the self 3 or 4 years, then in the space of 11 miles I had 3 die on me. Bought a new Bosch pump after that, would never bother with a second hand pump again unless it was only recently out of a car and it was to get me out of the sh!t.
Instagram - Kedge85
Post Sat Feb 28, 2015 7:24 pm
Those meat and doria pumps are about £75 after discount code for, cp4l think I'm gonna go for one of them
Post Sat Feb 28, 2015 8:28 pm
Kedge wrote: I thought a known good working pump would be fine sat on the self 3 or 4 years, then in the space of 11 miles I had 3 die on me.
I'm convinced it's the storage conditions that are the problem. The working parts of the pump are steel, and as soon as the petrol has evaporated, surface rusting starts.
Whenever I put a pump into storage, I remove the pick up filter, and pour a few ccs of oil into the pump.
Kedge
Post Sat Feb 28, 2015 8:31 pm
Could well be the issue, just being thrown on a garage shelf probably isn't the best of conditions. Was thinking the reason they packed up on me could be due to corrosion.
Instagram - Kedge85
Post Sat Feb 28, 2015 11:49 pm
Not noisy at all, as good as original
Ive had the same with pumps stored on the shelf/floor for a few years, connecting them directly to a battery before fitting and nothing happens :(
Mitchen
Post Sun Mar 01, 2015 2:53 am
Get a quote from Cotswolds on here for a 10% discount. Genuine parts cost the extra for a reason.. pay the 100 odd quid they charge and then have peace of mind that it's sorted and you won't need to touch it again for a long long time.
1990 320i Coupe SE
viewtopic.php?t=253048
Kedge
Post Sun Mar 01, 2015 3:01 am
You're in dreamworld if you think a pump costs £100 odd from BMW, times that by at least 3 last time I checked. I paid over £100 with trade discount for a Bosch pump last year from ECP.
Mitchen
Post Sun Mar 01, 2015 3:06 am
I would assume late 100's.. judging by Bosch retail prices compared to what Bosch BMW genuine parts I've bought had cost.. Never bought a fuel pump though.. but really?? £300?
1990 320i Coupe SE
Post Sun Mar 01, 2015 11:20 am
BMW prices are that ridiculous now that I rarely bother checking anymore, there is usually an OEM brand available from elsewhere which I will price up first
JF008
Post Mon Mar 02, 2015 1:08 pm
I called the dealer this morning for a price on a 318i in tank fuel pump, £314.60+vat.
Post Mon Mar 02, 2015 2:10 pm
The parts dept guys must feel like this - :jester:
Mitchen
Post Mon Mar 02, 2015 5:25 pm
JF008 wrote:I called the dealer this morning for a price on a 318i in tank fuel pump, £314.60+vat.
8O
At least you'd get it for 283 from cotswolds.
1990 320i Coupe SE
JF008
Post Wed Mar 04, 2015 6:44 pm
If it is of intersest to anyone thinking of replacing there fuel pump,
I replaced the old 118 000 miles o.e. in tank fuel pump with a Meat & Doria one. The old one was buzzing like a high voltage station, the new one as an audible but very quiet humming that I probably could not hear if I was not paying attention to it. So far so good!
I never swapped a fuel pump before and found it easy... after I realized I had to remove the fuel level sensor before I could wriggle the pump housing out, lot of fuel spilled at that point.
Nitrile gloves,new hose clamps and lots of paper towels are a must and the new pump will need soldering to its power feed and ground. There was no diagram available on real oem and I think I looked at bmwfans as well, anyhow, I did not realize there was an o-ring between the tank and the housing so I had reused the old one.
Easy job well worth doing,
JF
si911t
Post Thu Mar 05, 2015 9:54 am
Kedge wrote:You may as well buy the cheap unbranded new ones instead of a secondhand one Rob, my experience of old pumps has taught me they're a waste of time as well.
Oh fk I just bought a 2nd hand one off trader on here !!
Should have read this before I committed
Meatballs82
Post Sat Mar 07, 2015 1:04 pm
Mitchen wrote:Genuine parts cost the extra for a reason...
Rubbish! What's the difference between a genuine BMW suspension arm, and a Lemforder suspension arm sourced from ECP?
Same part, made in same factory but sold for two very different prices.
The ONLY difference is that one has BMW logo on it.
Main dealer snobbery is an expensive habit!
Post Sat Mar 07, 2015 1:25 pm
Meatballs82 wrote: The ONLY difference is that one has BMW logo on it.
Quite often the ECP one did have a BMW logo on it when it left the factory, which has been buffed off.
Post Sat Mar 07, 2015 8:09 pm
Seriously ? Not just plug in connections ?
**BANNED**
Post Sat Mar 07, 2015 8:11 pm
Correct!
And do fit them the correct way round..... :o: :cry:
Youth is wasted on the young.
Post Sat Mar 07, 2015 9:29 pm
Great. Although I can solder I'm not very good at it :cry:
Post Sat Mar 07, 2015 9:42 pm
Ive done a bit before, drop in with a stella or two if you want it doing mate :D
Post Sat Mar 07, 2015 10:05 pm
Got to get it out first mate - I need to fix it and tax it before I put the jag in for MOT just in case !
