What et is the E30??
stevetigger
Might get me some big wheels!
bootyman
15 or 20 i think
A1BMW325iSport
the 15" bbs are et24
some of the guys on here have gone for et20 and et30 when fitting 17"
Dan318-is
the et of 14inch bbs is 30, on the IS
Johan99
If you going with 7-8x18 I think ET20 is the lowest to go.
Johan
BMW 320is-90
BMW 320is-90
Hyperion
i am running bottle tops and they have a offset 25 (et25)
kam-325i
My 16"'s are ET 20
stevetigger
So 19" with et40
No good??
No good??
- Homo Hair
no.. they will foul on the strut
Kos
dips 19" were et 49 and he had tu use 20mm spacers!!!stevetigger wrote:So 19" with et40
No good??
so you could do th same
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
Kos
they sould be 30 or 35, i sure of itHyperion wrote:i am running bottle tops and they have a offset 25 (et25)
IG Pukar.Designs
IG Pukar.Designs
jonbuoy
stevetigger
I see now, so if you put a wheel on an E30 with et5 for example, it would stick out?? Is that right
Kos
bingostevetigger wrote:I see now, so if you put a wheel on an E30 with et5 for example, it would stick out?? Is that right
but spilt rims complicate it even more!!!!
it can be a complete head fuck with 3pc rims
IG Pukar.Designs
IG Pukar.Designs
stevetigger
So I should be aiming for et20??
jonbuoy
Kos
with 17" et 25-30 16" same agian 18" you need a 7.5 j rim no wider and 28et offset
it depend on tyre size too, some have a curved side wall which helps clearance under the arch
i'm glad its your head ache not mine!!!
have a stella and think about it!!!!
IG Pukar.Designs
IG Pukar.Designs
jonbuoy
Kos
16" et 24 205/50 tyres 40mm black bilsteins(sports) drop and rubbing!! you gota roll the arches or go for a lower profile. they are very sensetive to offset these e30'sjonbuoy wrote:So if i got 15" or 16" at et20, would i suffer with rubbing at 40mm drop with passenger's?
its mad because my old sport had bk171 alpinas 215/40 and the same drop but yellow bilsteins(sprints) and no rubbing!
IG Pukar.Designs
IG Pukar.Designs
- Homo Hair
got 16"x7.5" BBS with 205/50's on.. rub on the passengers rear only.. on a 40mm or so drop
jonbuoy
Johan99
8x18" with ET20 work fine on E30...Kos wrote: 18" you need a 7.5 j rim no wider and 28et offset
Johan
BMW 320is-90
BMW 320is-90
