Clio servo spacer required
booomer
Post Tue Feb 24, 2015 10:16 am
Does anybody on here make spacers for the Clio servo mod?
I need one but don't have the facility to make one
jmc330i
Post Tue Feb 24, 2015 10:22 am
A length of metal rod or suitable sized bolt and a hack saw. A bit of trial and error and job jobbed.
The length needed can vary from car to car, so not easy for someone else to make without access to your car.
James
'91 325i Sport
'93 318i touring 16v
Bristol_Jer
Post Tue Feb 24, 2015 8:24 pm
I used the shank of an old bolt I found in my spare bolt tin, cut the bolt head off and the threaded part, and then trial and error with the length as said. I drilled into one end slightly to make an indent so the pushrod would locate nicely, bit probably didn't need to do that.
It took me 2 attempts as I had it slightly too long to start with the brakes started binding after driving for a couple of miles.
So you just need a vice, a hacksaw and a bit of patience really!
