Hi,
I'm after a few parts for my e30, last 7 digits of the vin are EG10383.
2x fuel pump/sender tank orings, 63l tank I think, possible part no. 16111744639
3x plastic clips which hold the 3 fuel lines on top of the tank, I can provide a pic of required.
1 of each (LH & RH) heat shield bracket which attaches to the fuel tank and rear of the rearmost heat shield in the prop tunnel.
2x tank rubber mount with the metal spacer.
1x pressed metal cover for the vent pipes under OS rear arch going to expansion tank/filler neck.
2x upper front spring seat rubbers, if there is a choice, thicker ones please.
2x lower front spring seat rubbers, again thicker please.
1x mid exhaust hanger, the one fitted to the rear subframe.
4x rear subframe bracket to sill mounting bolts, these look like around an m6x20? bolt with a sort of flanged socket hex head.
Bit of a list I know, sorry! Hope you can help, thank-you!
Jamie.
A few parts please
Cotswoldbmw
Just before I start on this....
Have you retrofitted the 63L???
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
brucey
Ah, no it's a 318i lux, believe it came with 63l, I am however fitting a non genuine replacement from euro car parts. Thanks, Jamie.
Cotswoldbmw
Hi Jamie please take a look on website realoem.com and identify numbers needed. Thanks.
regards
Paul.
regards
Paul.
Cotswold BMW Parts
01242 335365
01242 335365
brucey
Hi Paul, I've found most of them, here goes:-
2x fuel pump/sender tank orings, 63l tank I think, possible part no. 16111744369 - I had written this one down incorrectly, this is the right number.
3x plastic clips which hold the 3 fuel lines on top of the tank, I can provide a pic of required.- Couldn't find these but will try 3x 16121176766
1 of each (LH & RH) heat shield bracket which attaches to the fuel tank and rear of the rearmost heat shield in the prop tunnel.- 16111177346 & 16111177347
2x tank rubber mount with the metal spacer. -couldn't find this
1x pressed metal cover for the vent pipes under OS rear arch going to expansion tank/filler neck. - 16131179011
2x upper front spring seat rubbers, if there is a choice, thicker ones please. - 31331128523
2x lower front spring seat rubbers, again thicker please. - 31331124322
1x mid exhaust hanger, the one fitted to the rear subframe. - 18211177828
4x rear subframe bracket to sill mounting bolts, these look like around an m6x20? bolt with a sort of flanged socket hex head.- 33311129676
Plus a couple of extras
12x plastic nut - 16131176747
6x hex head screw - 07119916966
Thanks,
Jamie.
Thanks,
Jamie.
Cotswoldbmw
Dear Jamie.
Thank you for your enquiry, the price for the parts required will be £149.86.
All prices quoted are for Genuine BMW Parts and include a discount for enquiring on line, VAT and no postage charge to a mainland UK address. If you need a price brake down please let me have your email address. Cant see the tank mounts you need if you look on the furl tank slides it does show all mounting parts needed.
Give us a call to place an order on 01242 588495 and please quote reference number 50210
Regards
Paul
Paul Webb
Parts Advisor
Cotswold Cheltenham
Main Telephone Number: 01242 257999
Fax Number: 01242 257150
E-mail: partscheltenham@cotswoldgroup.com
Website: www.cotswoldgroup.com
Regards
Paul
Paul Webb
Parts Advisor
Cotswold Cheltenham
Cotswold BMW Parts
01242 335365
01242 335365
Cotswoldbmw
No probs Jamie.
Cotswold BMW Parts
01242 335365
01242 335365
