I had an oil pressure switch (to replace my leaking one) when I did my oil change today but transpired it was the wrong type, so the old one went back on.
How much oil will I lose when replacing the switch? (I will do it after it has sat for a day so most of the oil is in the sump).
Ta
J
How Much Oil Will I Lose Changing Pressure Switch
- **BANNED**
Unless you attempt the swap with the engine running,
you will have no loss of oil.
Youth is wasted on the young.
