Radiator fitted but wants to boil over!!
ConvertChris
Post Sat Feb 21, 2015 3:58 pm
Hi
I have fitted a new radiator and filled with water, ran it without the cap for a while but it keeps wanting to boil over! i have undone the vent screw to try and expel any air, had the heater on but only cold air coming through with the temp gauge getting near the red!!
Car is a 91 318i cab
Any suggestions appreciated!!
Chris
BHadley
Post Sat Feb 21, 2015 6:10 pm
There is a way of bleeding the cooling system.
I'm guessing yours is the m40 engine?
If do mine was m42 but the same way applies as the whines are based on the same design.
The link may help
ConvertChris
Post Sat Feb 21, 2015 9:12 pm
Thanks for the reply, i did look through the tech help to see if had been asked before, should of looked further!
i will try the top heater hose tomorrow
