What size is the crush washer on the sump plug, and is it copper
Tia
sump plug washer
jimmyspeed
Not sure the size but it will be listed on the realoem website
I'm guessing you don't have the old one to measure? , but if you do most can be carefully sanded flat with fine 1500 grit wet and dry on a flat glass or machined surface
zd3bx
According to RealOEM > A12X17-CU
And it seems to be copper looking at this > http://www.realoem.com/bmw/photos/07119963151.jpg
jslot
Thanks bpth.,
I see what that part spec means now, its 12 mm inner diameter and 17 mm outer, the cu must be for copper
I do have one but it's still holding the oil in my engine! Just wanted to get everything ready before my super-service
Thanks again
Thanks again
Jona1971
I just bought one from BMW and its aluminium colour not copper.
Moredoor autos with small engines are cool - but my new m20b25 is awesome!
