Hi Guys.
I know that if using the ZF E36 M3 5 Speed, a 328i Driveshaft works fine and will bolt right upto the factory E30 Diff and be correct length.
How about with the ZF Getrag 6 Speed?
Because my Motor I got comes with a Getrag 6 Speed which I'm contemplating using.
Which driveshaft is known to be correct length and a bolt-in affair?
Thanks.
S50 using Getrag 6spd - Which Driveshaft?
