Dear All Hi,
I have an E30 325i and I want a LSD differential as my car does not have a LSD.
Can you please advice me which is the best LSD that I have to find? Ratio?
I want a LSD to improve also acceleration but to be ok for cruising as I am traveling.
Thank you in advance
Andreas
E30 325i HELP with LSD differential
about 7% longer, its not a huge differenceGTE wrote:3.91 vs 3.64 which is better? the 3.64 is much longer than the 3.91 correct??buster wrote:3.91 is what is fitted to facelift 325 with manual box. Pre face lift 3.64
E30 325is with M20B31
Thanks for your help!! Much appreciated!!reggid wrote:about 7% longer, its not a huge differenceGTE wrote:3.91 vs 3.64 which is better? the 3.64 is much longer than the 3.91 correct??buster wrote:3.91 is what is fitted to facelift 325 with manual box. Pre face lift 3.64
So now any one that has for sale a LSD 3.91 or 3.64?
Hi there I have found a 4.10 LSD that is for sale!
Is the 4.10 too 'short' will affect top speed?? Someone told me that the top speed will be not more than 100mph???
Will be the highway cruising ok or at 120-130km the rpm will be 4500??
Please advice asap.
Any help will be much appreciated.
Thanks in advance
Please advice asap.
Thanks in advance
A 4.10:1 will make any long distance run very tiresome as the engine will be revving higher with more noise. Even though there isn't a huge gap between a 3.91:1 and 4.10:1, I wouldn't go shorter than the 3.91:1.
Also the E30 4.10:1 LSDs are usually small case diffs which possibly won't last too long if pushed hard in a 325i.
An LSD won't improve acceleration, just your chances of getting sideways.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Hi there in order to source a 3.91:1 differential from which BMW model shall I look from?jmc330i wrote:A 4.10:1 will make any long distance run very tiresome as the engine will be revving higher with more noise. Even though there isn't a huge gap between a 3.91:1 and 4.10:1, I wouldn't go shorter than the 3.91:1.
I know that will not improve allot the acceleration but it will improve a bit and I will have an LSD!! If I am going to pay I would like the best combination at least!!
No I am not in the UK but postage can be arranged!!jmc330i wrote:Are you in the UK?
In the UK, the 3.91:1 LSD was standard on the 325i Sport, but could be specced from new on any 325i if the buyer wanted.
Do you know anyone that has such a diff for sale??
