fuel pump not getting any power
dbimmer
Hi guys. I have a 323i that suddenly died. Checked the fuel pump operation and no fuel was pumping. thought it was the pump. now replaced it and no luck. checked the relay and no power going thru. the green/violet and brown wires form 87b and 30 aren't passing power thru. were does the power come from so I can chase the problem? the electrical manual says it comes from the battery, but from where exactly?? any help would be appreciated
mark_i
323i... if you are still running with the original Jetronic this is a bit more complicated than the later 1.3 Motronic as you will have 2 fuel pumps: one in-tank and the other behind the sill in front of the rear wheel.
No power to the pump will be either the main relay, fuel pump relay or fuse F11
dbimmer
thanks. it is jetronic. and only has 1 main fuel pump. so as i see, 1 cable goes to the pump, the other one to power but I can't find where in the manuals. and i don't want to tear down the cables following it
