I've got a BTB 6 Branch and full straight through system on my 327 touring and may require some new gaskets!!!
I'm assuming that the manifold gaskets would be the same as OEM?
But I'm also assuming the BTB X-pipe(?) (where the mani joins the rest of the system) will need a non-standard gasket???
Any ideas if/where BTB gaskets can be bought - or am I better off leaving this up to the local garage to supply/make something???
They will be dismantling for me to try and find/cure a leak and I would rather just have new gaskets ready for them to put it back together with!!!
Cheers,
Rob.
BTB Exhaust system gaskets???
miniblob
327 Touring with bass!!!
reggid
at the head its an OEM gasket, there are also slip joints between primary and secondary/collector with no gaskets. dont know about downstream from the X-pipe as i dont have a full system but any exhaust place should be able to source whatever you need.
You might want some new rubber doughnut hangers etc to support the exhaust
E30 325is with M20B31
miniblob
Thanks mate!!!
