Headlight washer kit
snott
Post Fri Jan 02, 2015 5:32 pm
Im stripping my 318is as im turning it into a track toy, ive removed the headlight washer setup, motors, washer bottles etc.
I dont know if it works as it was disconnected when i bought the car but ill test the motors.
Im just wonder what its worth?
jonny323i
Post Fri Jan 02, 2015 6:10 pm
It's worth what you will accept for it for a true price search the for sale ads as the replies here will be very cheap if they want to buy it or very high from traders lol
Touring for life
e30-wheels
Post Fri Jan 02, 2015 6:16 pm
snott wrote:Im stripping my 318is as im turning it into a track toy, ive removed the headlight washer setup, motors, washer bottles etc.
As a guide i paid £45 each wiper motor and £38 for a relay on ebay 18 months ago
vytas85
Post Fri Jan 02, 2015 6:18 pm
full set will be wiper stalk,bottle,relay one more relay from fuse box 10pin,loom,pipes,motors,wipers and bottle for this kit you can get 150on ebay ease.
common problem are when motor shaft rust inside and then they stop working,i will be very surprised if yours still working :)
Post Fri Jan 02, 2015 7:28 pm
The motors almost certainly won't work, as said above. The output shafts will have seized in the long bush that the motors are mounted by.
They are easy enough to dismantle, clean, grease and reassemble, and will be worth considerably more if you guarantee that they work, and haven't broken anything while refurbing them.
The motors are protected electrically from burning out while seized, and out of the many that I've repaired, I've only had to bin one, which had leaked water into it somehow, that had completely rusted away the metal case of the motor.
