Part no.61661374978 question.
ah
Post Wed Dec 31, 2014 5:59 pm
This is a windscreen washer valve which is the last connection to the windscreen washer jets,nozzles on the bonnet.The drivers side nozzle stopped working,thinking it was blocked I tried to clear it with the usual tools a needle,pin ect but no luck.when I lifted the bonnet and tried the washers again, water was spaying out of one of the 2 holes in the main body of the valve.The 2 holes look like there meant to be there but for what reason?Ive ordered a new one,will this cure my problem.
zd3bx
Post Wed Dec 31, 2014 6:11 pm
Had the same problem, but it turned out to be the clip that was holding the hose to the valve, not the valve itself.
See my post here > http://www.e30zone.net/modules.php?name ... 31#2593531
Are both of the hoses attached to the valve using the clips shown in my post?
ah
Post Wed Dec 31, 2014 6:23 pm
The clips are there and in perfect condition,as I said it's coming out of one of the two hoes in the body of the valve.
ah
Post Wed Dec 31, 2014 6:56 pm
Thanks diable,but what are the holes for?
ah
Post Wed Dec 31, 2014 7:19 pm
O well I can sleep tonight cheers mate
zd3bx
Post Wed Dec 31, 2014 7:59 pm
Talking of eBay, this will probably do the job
http://www.ebay.co.uk/itm/Genuine-Non-R ... 51bfa281d0
As far as I remember, the genuine BMW one wasn't too pricy either, about 10 quid from memory?
Post Wed Dec 31, 2014 9:41 pm
diable wrote:Oh and as mentioned above if the clips have failed they a couple of small cable ties.
16131379229 for the correct clips which are pence.
