M52 Tuning
- Brianmoooore
Replace it with one from a 328i, or even a 330i.
jimbom30cab
- Tech 1 freak
8 to 12 hours
Grzesiek325i
If the engine its form E46 you got M52B25Tu (2x vanos).
Quickest and most powerful replacment is M52B28Tu. Should be p&p
Fitting M54 would need a minor modifications
Why the feck would someone go to the trouble of converting to m52b25, now I'm going to have to pay to have that ripped out!DanThe wrote:Its still a waste of time tuning. 2.8 is what you needMuzz2676 wrote:The current engine is from an e36 323i, I've edited my first post
Grzesiek325i
First and the best modyfikaction without changing engine to M52B28 is intake manifold from M50B25.
As you've just bought the car, I'd suggest just getting in, driving it and having some fun for a while. Forget making it faster until you've learnt to drive it.
Then as above, get yourself an M52B28... and while you're enjoying driving the car, build a tasty M52B30
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Grzesiek325i
You are using bottom end from M54B30 with block and head from M52B28.
imho its better to swap M54B30 in good condition.
Proper building engine its not a easy job
Its easier for you to just fit an M52B28 and use it as is, plenty out there.... unless you have the time to build an engine and the associated things to go with it. I saw your thread on CS - search my username on there and you will find my M54 engine build thread.Muzz2676 wrote:Sounds good for the future. Who here can source build and fit such an engine?
