Oil Pressure Values please.
jmec
Post Tue Dec 23, 2014 5:50 pm
Hi. I've just fitted an oil pressure gauge (& voltmeter) using the Wiki guide (very good). Does anyone know what pressure values I should be seeing at, cold idle, warm idle, hot idle, cold 2500 rpm, hot 2500 rpm for an M20 (325) using fully synthetic oil? Thanks. And here's hoping for a couple of bob for xmas to spend on my cab!
Grrrmachine
E30 Zone Wiki / Team Member
Post Tue Dec 23, 2014 6:26 pm
No idea at particular revs, but my 5-bar guage usually shows MAX when stone cold, dropping down to 3 bar when the coolant moves off the blue, then down to about 1-1.5bar when properly hot.
Whether your oil is mineral or fully synth won't make a blind bit of difference to your readings :D It's the weight that matters (5W30, 10W40, 20W50 and so on). My readings are for 5W40.
gromgsxr
Post Tue Dec 23, 2014 10:11 pm
i get about 60psi or so at stone cold idle, down to about 15 fully warmed up engine and on motorway speed 3000 ish rpm 51 psi
jmec
Post Wed Dec 24, 2014 3:55 pm
Thanks Gents, yes I should have mentioned the oil spec it's 5W-40 and the readings are near to your info.'
