High compresion 325i block casting number/s?
sweep
As above does anyone have any info?
Look on the machined flat to the right of the inlet side engine mount, just above the block:sump interface. High Comp = 25 6E, Low comp = 25 6K.
There may be additional info, e.g.;
25 6E 1 = Early high comp. 9.7:1 CR.
25 6E 2 = Later high comp. 9.4:1 CR.
(25 6K = Low comp. 8.8:1 CR.)
You may need to wire brush/Jenolite the area to see it, and use a strong torch.
sweep
I have 25 6e 1 here..
Congratulations, that will probably be the early high comp. with 9.7:1 compression ratio. Normally good for 180bhp or so.
sweep
trying to identify the pistons for a customer .block on the oval casting say's 86
Sounds about right - the 325i was introduced in 1986.
This guide gives info on pistons:
http://www.e30zone.net/e30zonewiki/index.php/M20
You may also find info on RealOEM, etc.
sweep
Thanks .
