Evening all,
My front fogs randomly stopped working today...I have checked and replaced the fuses and the K8 Relay but still nada!
I get the green light on my dash to say the fogs are on but nothing from the front....the fuse box makes a "click" every time I turn the fog lights on and off....
Any ideas?
Front fog lights not working
The green tell tale light is powered from the output side of the LH foglight fuse, so if it's on, everything is OK up to here.
That just leaves the wires to the foglights, the lights themselves, and the earth wires for the lamps. The only common point between the two lights is the earthing point at the front of the LH inner wing, so check that out first.
