changing front top mounts
Cloggy Saint
BenHar
No.
Ben
Ben
Topblag
Top tip, whilst you have the chance, spray lots of penetrating fluid onto the nut which holds the damper into the strut and see if you can get it moving when the strut is off. Remove it, clean up the threads and put copper grease on the,, make sure there is a teaspoon of oil in the strut before you put the damper back in.
They are a bitch when they are seized.
Also make sure you loosen the top nut of the damper before you remove the wheel.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
