just wondering where people have put exhaust brackets as there was one on the original m20 gearbox but i have a zf box now and the exhaust is only held up from the mani and the back box!!
the throtle cable i have bought has like a metal sleeve on the end i have bent this to the shape of the bend ,on the throttle body but sometime it seems to get stuck and rev. is there another throttle cable that is just flexi cable till the end?
and finally it revs but hunts abit when i let the throttle off before it settles and if its drivin in the yard hard and i brake it cuts out I'm sure all cables and pipes are in i wanted to plug it into the computer, where about would i have to plug it into?
cheers
jon
exhaust brackets, throttle cable sticking, fault codes how t
