M20 fly and clutch ZF box biting point!!!
rich318i
Post Sun Oct 19, 2014 9:14 pm
where is your biting point ?
Top of the pedal or close to the floor?
HairyScreech
Post Sun Oct 19, 2014 11:41 pm
M20 with e36 box here and extended pads on the clutch fork, so same deal, clutch is totally normal.
rich318i
Post Mon Oct 20, 2014 12:28 am
HairyScreech wrote:M20 with e36 box here and extended pads on the clutch fork, so same deal, clutch is totally normal.
that didnt really answer the question.. where is your biting point?
HairyScreech
Post Mon Oct 20, 2014 1:11 pm
Same as it was before, about 50/60% of the pedal travel, one thing that makes a huge difference is replacing the master cylinder or the piston part at least. When the rubbers on the piston are worn it gives some odd effects, before doing that mine would pump up and down.
