Post
Mon Oct 13, 2014 7:40 pm
Looks like the end of the cable outer is still in there.
I suggest you buy your new cables now, so you can see what you're dealing with.
Careful action with a drill of the appropriate size should get most of it out, or you can try a parallel punch from the other side, but the hub flange gets partly in the way.
