PCV conversion on m50 inlet and props haft bearing and temp
and1_e30
Post Sun Oct 12, 2014 10:18 am
hi i bought the car with the m50 mani already on, but the pcv pipes were terrible. the pipe going back to the intake was reduced down to a vacuum sided pipe, and where it connects onto the pcv the pipe was bait too small and has split swell :|. i have welded the pipe on the dipstick and i have just purchased the e34 525i intake boot. my question is what size are the pipes and elbows i need? it would speed me up ordering them now and less time on waiting for parts to arrive :) :)
second is the propshaft bearing i have the zf box and i am using the e36 prop and need the e30 centre bearing. i bought one off ebay fitted it and it is slightly different and the rubber has come away from the bearing already and its not even on the car yet :| does anyone know where i can get a decent centre bearing from but not break the bank?
the brown e30 temp sensor is in,does the wiring go to the c101 plug? both wires or just one?
cheers
jon
Motorhole
Post Sun Oct 12, 2014 11:21 am
iirc pre-facelift and facelift centre bearings are different.
I got a Febi-Bilstein one from 123spareparts.com. Other options are GSF or a dealer I guess. Wouldn't bother with a cheap one, replacing it isn't a job you want to do twice if you're planning on keeping the car for a while!
and1_e30
Post Sun Oct 12, 2014 1:52 pm
That's probably what I have done then!! Cheers I shall order one off there :)
