Using the e36 328 prop with an e30 centre bearing but I'm unsure if the bearing goes in reversed ? and do you use the e36 prop bearing holder or the e30 one ?
Thanks in advance
S50 conversion prop problem
Offer it up to the car and it becomes obvious, 'reversing' is bad wording, the E30 centre bearing carrier will only fit the body one way
