Brake pipes
Jona1971
Post Wed Oct 08, 2014 4:52 pm
I have an advisory on my new MOT which says both my front brake pipes are slightly corroded and both front brake hoses are slightly deteriorated.
I can order the brake hoses from GSF/ECP/CP4L but they don't stock brake pipes.
Any ideas where the best place to source these from are?
Many thanks,
steve_k
Post Wed Oct 08, 2014 4:59 pm
get a roll of copper brake pipe & a flaring kit & pipe bender & brass unions & make your own,
or get them ready made from bmw.
Jona1971
Post Wed Oct 08, 2014 8:57 pm
Ok, never done that before, sounds fun. 25ft copper from fleabay for £25 plus a flaring kit etc.
Copper or cunifer? (I'm guessing Cu-copper, Ni-Nickel, Fe(r) -Iron? I could be very wrong).
I can't possibly mess this up right? I mean just take the grubby one off and bend a new one the same as a template?
Cheers, (new to this)
steve_k
Post Wed Oct 08, 2014 9:03 pm
No worries,
Is easy enough, get enough copper piping & have a try, its the best way, don't try, don't know.
Jona1971
Post Thu Oct 09, 2014 5:25 pm
Brill, will do.
Post Thu Oct 09, 2014 6:40 pm
Jona1971
Post Sat Oct 11, 2014 9:25 am
Thanks Brian, I was just about to buy the cheap one, this one looks much better.
Am I going to make the same mistake with the copper, or will this do: http://www.ebay.co.uk/itm/280887932288? ... EBIDX%3AIT
Also, Copper or Cunifer?
Thanks in advance, want to get it ordered and on the car... :)
Post Sat Oct 11, 2014 10:23 am
Cunifer every time. You need M10 short ends, and it's a good idea to renew the U shaped spring clips that hold the ends of the flexible lines in place. These are only pennies from BMW.
Jona1971
Post Sat Oct 11, 2014 2:28 pm
Is that these nuts:
http://www.ebay.co.uk/itm/Short-Brake-N ... 483fabb16f
One at each end?
Post Sat Oct 11, 2014 6:38 pm
That's the ones, but they're probably cheaper at your local motor factors.
