Replacing Rubber Guibo (Steering Linkage)
zd3bx
Post Sun Sep 28, 2014 12:00 pm
I'm going to replace the rubber guibo in the steering linkage, but before I do that, just wanted to make sure I've got the right part number?
The car is a 1990 325i with P/S.
Here's what I'm looking at > http://www.realoem.com/bmw/showparts.do ... g=32&fg=30
So the part that I need is no 3, correct? (32 31 1 153 993)
Also I noticed that mine doesn't have regular nuts and bolts holding it, but it looks like this:
So I'm assuming I will need to buy new bolts/nuts/washers as well? (items 6, 7 and 10 in the diagram)
By the way, what happened to Cooper BMW Parts website? (http://www.cooper-bmw-parts.co.uk/)
It was great for checking the availability and price of the parts before ordering anything, but now it's been in maintenance for quite a few months...Any alternative for checking BMW parts prices online?
Would be good to know how much that UJ guibo is...
jimbom30cab
Tech 1 freak
Post Sun Sep 28, 2014 12:46 pm
If you dont go bmw, they are about £10 to £15 from places liie mr auto
If you are ok waiting a week, I am getting a solid one made from aluminium, if its good I could get another done if you like?
zd3bx
Post Sun Sep 28, 2014 9:14 pm
jimbom30cab wrote:If you dont go bmw, they are about £10 to £15 from places liie mr auto
I found FEBI one on Ebay for 18 quid, so that's one option...
Any advantages of an solid aluminium one over the OEM rubber?
aimlessrock
Post Tue Sep 30, 2014 10:40 pm
+1 whats the advantage of a solid one over a rubber oem ??
E30 320i Convertible (1989)
190 Mercedes (1988)
Post Tue Sep 30, 2014 11:02 pm
One less thing to potentially wear out, and a more direct steering feel, although the Zone Wiki claims the rubber one is designed to reduce noise travelling up the steering column:
http://www.e30zone.net/e30zonewiki/index.php/Steering
aimlessrock
Post Wed Oct 01, 2014 11:16 pm
Cheers Maurice, my steering linking is the same as the OP..how do you get to the guibo?..as it is riveted into place”¦assume you can just drill them out?
Ive scoured the wiki and could not see a guide..is there a guide?
190 Mercedes (1988)
