E30 Innovative Goods projects - SI shiftlights, multigauge..
E30IG
Post Mon Sep 22, 2014 9:39 am
Hi,
I am a member of a team of E30 enthusiasts. We like to make things, gadgets that make our E30s more fun to drive. We named our product line E30 Innovative Goods - E30IG.
First of our project is Service interval shiftlights. We wanted to keep the service interval functional so we had to investigate how the original board operates with LEDs. After a few trials and errors we got it.
Then it was time to find a way to get rev reading. With a use of oscilloscope we monitored the signal to cluster and got an idea how to read it and display it as shiftlights.
So the first breadboard version of shiflights was born.
Then we designed first PCB, side by side with original SI LED board.
Since there are a lot of things to think about, how to position parts on PCB that cluster can be assembled together, first PCB wasn't good, so we had to do another version, and another...
All signals can be "picked up" on connector that connects SI board to main cluster board, but how on earth can we hijack them without soldering...a lot of thinking made it happen and after a lot of experimenting adapter was made.
These aren't all versions...
Final version on its place.
Final version of PCB that does it all. Those LEDs are 9000mcd, prepare your welding mask.
So, what does it do?
When you turn your key to Accy position LEDs show you service interval reading. With ignition on shiftlights are activated.
Our goal wasn't making night rider cheesy look shiftlights that goes on with 800rpms but to make it as realistic and funcitonal as they should be.
So we decided to take the rpms where engine torque starts to drop as a max, all seven LEDs starts to blink.
Then with max-200rpm...5 green, yellow LED ligths on,
with max-400rpm...all 5 green LEDs are on,
with max-600rpm...4 green LEDs are on,
with max-1200rpm...1 green LED is on.
Below that no lightshow...
To keep things more complicated as they already are, these tresholds are dependent of engine temperature.
When engine is cold everything starts to happen earlier.
As I mentioned before LEDs are realy bright, shiftlights are supposed to be so bright that you keep your focus on the road/track and know what your rpms are. But if someone wants to set the brightness it can be done.
How can you set the brihtness with no potentiometer...I came up with a solution that may sound weird but it actually works.
I studied the onnector that connects SI board to main cluster board and found out a way to use Fuse21 to help me
Brightness setting procedure:
0. open the hood of your E30
1. locate the fuse box and open it
2. remove Fuse21
3. insert modified fuse with wires and button long enough to press/depress the button from your driverseat OR ask somebody, anybody or your buddy to help you
4. startup your car
5. press the button, Fuse21 "goes off" as a result tacho goes off too
6. with revving your engine you are changing LED brightness, 100% at cca 1200rpms. When you get to the brightness which suits you just depress the button
7. your favorit brightness is stored.
Next project is hazard switch digital multi gauge. It is capable to measure four different things and voltage. For instance oil temp, oil pressure, fuel pressure, cooling temp.
It fits into a hazard switch, with a LED display cover made of plexi glass that is shaped like original hazard switch dark red plastic. The whole thing will work as a switch, when youpress it it will toggle to another measurement with text displayed...let pics do the talking...
BTW, chars are evenly illuminated, pics can be misleading.
And another project...try to figure out what could it be.
Comments, ideas and critics are welcome.
E30IG
Post Mon Sep 22, 2014 10:35 am
diable wrote:Good luck with the projects, you need to post up some videos of this in the car and working.
This is a video shot during development, notice that LEDs are not the ones used in the final version. Threshold was set to light the first green LED almost from idle.
[youtube][/youtube]
Post Mon Sep 22, 2014 11:05 am
Looks impressive. What are you using for the control logic, a PIC microcontroller?
I'm guessing the other gadget is some sort of wash/wipe controller, for either headlamp washers or windscreen/tailgate wash/wipers.
E30IG
Post Mon Sep 22, 2014 11:50 am
Speedtouch wrote:Looks impressive. What are you using for the control logic, a PIC microcontroller?
We are using Atmel's AVR microcontroler for the control logic.
Good guess. The last project is a programmable windscreen wiper interval control relay. Details will come later.
TriggerFish
Post Mon Sep 22, 2014 1:03 pm
Awesome, I love this kind of thing!
What sort of price range do you imagine this will end up at?
E30IG
Post Mon Sep 22, 2014 1:22 pm
TriggerFish wrote:Awesome, I love this kind of thing!
"Shiftlighs" is the closest project to finishing. There's been a whole lot of hours put into R&D.
If anybody is interested in this item, we can make some extra and sell them for 105 GBP (postage included).
HairyScreech
Post Mon Sep 22, 2014 1:36 pm
:bow:
Nicely done. Shift lights are easy, shift lights that keep the SI function is not so easy but a perfect solution.
Post Mon Sep 22, 2014 7:29 pm
Very interested in the multi gauge. Any ideas on price?
appletree
Post Mon Sep 22, 2014 10:37 pm
I'd be interested in a intercooler before i/c / after i/c air temp read out to go in the over head check control panel if it's doable, be thinking about making one for a while but never got around to it. :(
E30IG
Post Tue Sep 23, 2014 8:23 pm
bss325i wrote:Very interested in the multi gauge. Any ideas on price?
We don't have a price yet. Will keep you posted.
E30IG
Post Tue Sep 23, 2014 8:27 pm
appletree wrote:I'd be interested in a intercooler before i/c / after i/c air temp read out to go in the over head check control panel if it's doable, be thinking about making one for a while but never got around to it. :(
It can be done.
Do you have any sensors for that?
appletree
Post Wed Sep 24, 2014 7:12 am
In the past I have used some thermocouples connected to two fluke temperature meters and added two 1/8th BSP bosses to my boost pipework so I could take some measurements during development but It would be nice to have a neat set up that was always connected with double read out. :D
bmw9818
Post Wed Sep 24, 2014 7:31 pm
id be interested in one as well
Bristol_Jer
Post Wed Sep 24, 2014 7:34 pm
Do you already make a conversion that turns the service lights into shift lights but not still using them as SI indicators?
E30IG
Post Fri Sep 26, 2014 8:31 am
Why would you want that, are your SI indicators faulty?
Bristol_Jer
Post Fri Sep 26, 2014 4:24 pm
It is a track car, so not bothered about service indicators as I just service the car every few trackdays
Jona1971
Post Fri Sep 26, 2014 4:52 pm
Looks amazing, very innovative.
Keep us all informed of your progress and good luck...
E30IG
Post Mon Oct 06, 2014 7:34 am
Video update...calibration. I suggest that you watch it in HD directly on YT.
Threshold for first LED and step can be custom set prior to shipping.
[youtube][/youtube]
pony
Post Mon Oct 06, 2014 9:36 am
This is great idea. Subscribed :-)
Jozi
Post Mon Oct 06, 2014 10:57 am
Its telling me the video is not available on my tablet
E30IG
Post Mon Oct 06, 2014 6:40 pm
Jozi wrote:Its telling me the video is not available on my tablet
Thank you, didn't know that. I had to sort things out. Please try again.
Jozi
Post Mon Oct 06, 2014 11:00 pm
Works perfect!! Cool wee mod, might just have to stick it on my list of things i want
George
Post Tue Oct 07, 2014 9:29 am
Great project, very impressive - well done. 8)
E30IG
Post Fri Oct 10, 2014 9:50 am
We decided to add a switch so you can use it to switch between day/night illumination.
If you want to use it as on/off switch just set day illumination to lowest setting possible.
Switch is an option, if you like it you use it, if you don't then there is no need to route wires etc...
Demlotcrew
Post Sat Oct 11, 2014 4:02 pm
Great project!
You should start a crowd source account and get people to pay for this up front, really does work!
Andrew
E30IG
Post Mon Jan 04, 2016 9:39 am
Hi guys,
it took us a while, but we finally got the time to finish this product.
We are selling them all over the world.
Maybe some of you are also interested in buying.
Bellow is a short video to show you how it works in action.
If you are interested drop us a post or go to our website http://www.e30ig.com
[youtube][/youtube]
E30IG
Post Tue Jan 26, 2016 7:03 am
Hi guys,
just a bump.
We've sold over 60 sets in the last few months since we started pushing this product.
If anyone is interested drop us a post, an email or visit our www for more information.
On our www there is a map where you can see where the sets were shipped... :)
Cheers, Joe
JoshH
Post Wed Jan 27, 2016 9:16 am
E30IG wrote:Hi guys,
just a bump.
Cheers, Joe
Looks awesome! What's your website please I would like to order one!
